| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | So assuming you have a separate voltage regulator, more or less stock wiring and an ammeter..............assuming alternator is wired properly to regulator and etc.
1. Black Wire from ammeter pos to 6 pin connector. Thru connector to starter solenoid "B" (battery) terminal. 2. BLK with WHT stripe wire from ammeter neg to 9 pin connector. Thru connector to horn relay Battery terminal/screw. The horn relay does double duty as a power distribution point/junction block, whatever you want to call it.
Not sure about original wire colors since you are switching clusters, and not sure if they have been changed by PO, so wire per above regardless if colors match.
If no change in issue after answering questions and wiring per above, we will begin trouble shooting if you wish.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
