0 members (),
125
2
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If you haven't changed the angle of the engine or the rear the angles will be correct. In order to the correct drive shaft measure from the center of the front U-joint to the center of the rear U-joint and a driveshaft company can build you a driveshaft from these dimensions. I have driveshafts built quite often. Trying to find a used driveshaft that will work isn't worth the effort. Put the slip joint in the transmission, measure from center of joint to center of joint. Take the slip joint and the rear joint to a drive shaft shop and they will build a shaft. I took trig in high school and college. But you are trying to make something complicated out of something very simple. | | |
