| | | Forums66 Topics128,181 Posts1,057,177 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 73 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 73 | The thought was if there was something to modify it for better drainage it’d be better to do before paint. The truck won’t see a lot of water. Although I’m sure there will be water in the back from either a rain storm here or there or washing the truck. The front panel is lower then the cross member and the holes to attach the boards so the water will collect on that front panel. Proved that today while wet sanding. I could drill a few holes in that piece I suppose. Thanks Kevin I have seen that suggestion, that’s the suggestion I was alluding to in my initial post. I was going to do that to the boards. I’m just trying do any little tricks to help keep the truck in good condition for the duration due to the amount of time and money I have in to the truck. Thanks
Adam
Entire Thread
Truck bed, 47-55.1, drain holes
| Adamg | 03/26/2023 12:44 AM |
Re: Truck bed, 47-55.1, drain holes
| Otto Skorzeny | 03/26/2023 1:28 AM |
| Gdads51 | 03/26/2023 1:35 AM |
| 2ManyTrucks | 03/26/2023 1:46 AM |
| KEVINSKI | 03/26/2023 1:05 PM |
| Adamg | 03/27/2023 4:00 AM |
| dgrinnan | 03/27/2023 1:02 PM | |
