| | | Forums66 Topics128,187 Posts1,057,214 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | The 216 and 194" Gen-3 use the Rochester "B" with 1-1/2" throttle disc and SAE #2 (small) flange pattern. 194: 1-1/16" venturi 216: 1-7/32" venturi
I also found a larger #2 flange carburetor: 1-9/16" throttle disc, used on some Pontiacs (OHC L6?): 1-5/16" venturi | | | |
Entire Thread
216 Intake / Exhaust Manifolds on a 235, help?
| Dusty53 | 03/16/2023 12:20 AM |
Re: 216 Intake / Exhaust Manifolds on a 235, help?
| JW51 | 03/16/2023 12:24 AM |
| JW51 | 03/16/2023 12:27 AM |
| Otto Skorzeny | 03/16/2023 12:29 AM |
| panic | 03/16/2023 1:40 PM |
| Skooter | 03/16/2023 12:35 AM |
| JW51 | 03/16/2023 11:06 AM |
| Hotrod Lincoln | 03/16/2023 2:24 PM |
| JW51 | 03/16/2023 2:41 PM |
| 52Carl | 03/17/2023 1:29 AM |
| Dusty53 | 03/16/2023 4:11 PM |
| Otto Skorzeny | 03/16/2023 7:00 PM |
| panic | 03/16/2023 10:17 PM |
| Dusty53 | 03/16/2023 10:28 PM |
| Hotrod Lincoln | 03/16/2023 4:26 PM |
| JW51 | 03/16/2023 4:38 PM |
| JW51 | 03/17/2023 3:19 AM |
| fixite7 | 03/17/2023 2:13 PM |
| Dusty53 | 03/17/2023 4:49 PM |
| fixite7 | 03/17/2023 9:37 PM |
| Dusty53 | 03/17/2023 4:44 PM |
| Hotrod Lincoln | 03/17/2023 5:40 PM |
| Hotrod Lincoln | 03/17/2023 6:18 PM |
| Dusty53 | 03/17/2023 9:34 PM |
| Dusty53 | 03/17/2023 10:54 PM |
| 1Ton_tommy | 03/19/2023 8:19 PM |
| Dusty53 | 03/19/2023 9:47 PM | |
