I am posting some pictures of my drivers door gaps. You tube has some ideas but I wanted to pass my question on to the Bolters. So the gaps are fine as they sit, the door opens and closes without touching. After epoxy primer the gap will get vary small and in some places the door will scrap the hinge and latch posts for sure. The gaps that are not close to scraping are relatively accurate to the desired gap. The hinges are tight and do not allow the door to hang improperly. So, how would you all shrink the door?
