Kevin,
Should I cut at my original weld line?
If I am following you correctly, I cut horizontally, and as I get closer to the door, try massaging the piece clock wise to align it with the door. As Mark indicated, I might need to make a vertical slice too
Or do you mean cut the panel completely off?
1954 3100 with Hydra-Matic
Currently undergoing S10 conversion
Parkinson’s...it’s not just for the elderly
Caution, slow man at work
