Originally Posted by DES57
“M8x25mm Rivet Countersunk Hex Socket Cap Bolts and Hex Head Barrel Nuts”
METRIC threads on a Stovebolt?!!!! nono wink
I don't think you'd need to worry about inadequate strength on those fasteners, but I'd probably go with something more conventional rather than barrel nuts. You could easily get conventional bolts in grade 8 if you feel the need.
Kevin
1951 Chevy 3100 work truck
Photos
