| | | Forums66 Topics128,033 Posts1,055,531 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,759 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,759 | Suspending the engine/trans assembly without some support at the bell housing will break the bell housing. You'll need a 1961 V8 bell housing with the hydraulic clutch setup, with the throwout fork and slave cylinder on the passenger's side. Then it will be a bolt-in swap. Saginaw 4 speeds have a cast iron case- - - -no rear mount should be needed, but a universal tubular mount the hotrod shops sell would be an option. DO NOT do the front/rear mount setup without supporting the bell housing. Jerry
