| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | I think Evan (coilover) made some of these a few years ago...3 years, maybe? You might send him a PM. If you need to shim the front part of the cab up higher (it will commonly sit down on the frame and avoiding that by even 1.5 or 2mm will eliminate a decent amount of noise coming from the frame straight into the cab) get some of the sheet pvc material used for shower pan liner and cut yourself some washers from that. It is thin enough you can use a couple or three layers. That noise is the same principle as two cans and a string for a "telephone."
