| | | Forums66 Topics128,077 Posts1,056,281 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Are my bearings in the easier-to-find or harder-to-find group? Nervously awaiting reply...  You're in luck- - - - -that's the later style bearing. The early ones had dowels on top and bottom, and used shims to adjust the clearance. The tabs on the upper bearings started in mid-year 55, IMHO, and went to 62/63. The early blocks can be modified to accept the later bearings, but then the crankshaft has to be custom ground and polished to get the right oil clearance. Jerry
