I have a 39 216 has a cracked block with 3 speed transmission. I have a 1958 235 it doesn't have the flywheel or starter. Can I use the flywheel from the 216 and put it on the 235? Also I need a distributor for the 235. What part numbers do I need to look for? Thank you for your help.
