| | | Forums66 Topics128,131 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | I used 1.25" although I could have used 1.5 just as easily. 1.25 worked a little better with the perches I had. Actually you can use 1 inch if you wish. The difference between 1" and 1.5" won't actually be seen by the eye as much as you might think. 1" will let you pick up a wee bit shorter turning radius...again not enough to make much difference.
