0 members (),
135
0
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | The side cover is completely different on the Saginaw transmission. The spacing of the shift levers is wider than the original so fabrication and bending of the shift rods will be necessary. 60's columns were different also. Good luck even finding those components. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
