7 members (Otto Skorzeny, dt235sd, Cosmo, Hanks custodian, klhansen, JW51, Lostbuthaulinass),
105
2
Mod | | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 5,830 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,830 | Rovertech, Going by your signature line, guessing you are asking about your '58 1/2 ton (I think I recall you saying elsewhere it had a 283???). Check out this PDF file (link below) that shows the '55 2nd Series (Task Force) wiring diagram from the '55 Shop manual. This applies to your truck as the following years 56-59 only had "Supplements" published for shop manual changes. A look at those "Supplements" showed no changes to this wiring diagram. http://chevy.oldcarmanualproject.com/electrical/wiring/pdf/55truck.pdfYou can save the file and print as many copies as you need to help you get started on your wiring.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
