Can anyone tell me the easiest way to wire a 55-57 chevy car 3speed w/overdrive. When going into overdrive do I activate the overdrive solenoid first or the manual kickdown switch? When I am cruising at any speed and let off the accelerator the engine goes back to idle and then when I press down the accelerator the tranny won't kick back in right away. What's up with that? I am using a 235ci+ 3speed w/od+ 3.90 rearend. Is this a good combo? Thanks Joe
