Hy Super55 and Guys, way back when they only put two clearance lights on the cab one at each leading corner and they were green. Sometime later they added the three in the center as well. Green was the legal colour of forward facing clearance lights until 1965. If you have a specialty plated vehicle that is 1965 or older the green clearance lights are still legal, hope that helps.
