| | | Forums66 Topics128,167 Posts1,057,022 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Is it possible the pickup tube has simply gotten bent? Try measuring the distance from the oil pan rail to the bottom of the pickup tube, and compare it to the depth of the oil pan in the same area. Then do whatever it takes to get just enough clearance between the pan bottom and the pickup tube to suck up the oil without creating any restriction. Sometimes the simplest solution is also the best one. Jerry
