| | | Forums66 Topics128,210 Posts1,057,459 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | Ron, it was probably me that misunderstood.
Looking at your middle picture, are the two bolts straddling the safety catch opening the ones that are hitting? If I recall correctly, those bolts on mine were pan head with clutch driver slots, which would be a little less proud than the hex heads with rim that your bolts appear to be ( a little hard to tell.)
