| | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14849 08/12/2002 8:33 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Mechainiac's right. The 230 is a narrower block, requires different motor mounts. Your tranny should bolt up to the bell-housing, the 230 used the SM-420. Better engine than the 235, but not as good as the 250 or 292. Depending on the budget, I would go with a 261 if I wanted to stay with the existing mounts, or a 250 or 292 if I were willing to change the mounts.
Fred 52 3600 69 C-10
