0 members (),
170
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | The 1948-1952 Shop Manual lists 4 psi Max pressure for the fuel pump and makes no distinction between years or engines.
Even though the specs say 4psi Max, the output of my pump at the carburetor is 2.5 psi and the truck runs just fine.
I'd rebuild the glass bowl pump and install it and see what happens.I'm sure it will work fine.
1950 Chevrolet 3100 (Ol' Roy)
