Nothing major, but started swapping out the ratty old tires for new ones. Running 8.25-20 on the rear and 7.50-20 on the front. Thought I was going to be slick and keep the fronts on while I mounted the new 7.50 on one of the rims from the back. Worked great, until I went to install it. I don’t know if this is common or what, but my center hole diameter is 4.75” on the rear and 5.25” on the front. 🤦ðŸ»â€â™‚ï¸
