| | | Forums66 Topics128,196 Posts1,057,386 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | It' easy to measure the "clearance ramp" using a set of V blocks to support the cam and a dial indicator. The area of the lobe just off the base circle will have a short area of gradual lift before the valve lift actually begins. Measure that slow lift ramp and set the clearance accordingly. Don't forget to factor in the rocker arm ratio in the process of measuring the clearance ramp. It's much simpler to do the math with the cam installed in the engine and a degree wheel on the crankshaft. Position the dial indicator on the rocker arm tip directly above the valve stem. Jerry
