I shimmed the crank pulley out with an aluminum spacer. I really did not want to take the new water pump apart and try to press the flange on further, the back sie of the flange has an integrated shoulder that gets very close to the pump housing so I could not determine (without disassembly) if I could move the flange without casuing seal problems.
