8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln),
78
3
Mod | | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I suppose you can get it that way too. Just do a search, actually I think I saw it that way when I was looking for the stuff I linked to. Personally I'd rather be able to use a small applicator and pull back the seal with a seal tool to put in where I want it. I don't think you want sealer any place while your using a rope to install the window and rubber seal. Maybe some sealer in the channel for the glass before install because it would be next to impossible to get sealer there after the install. But around the pinch weld that could be done after the install, I think.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
