2 members (WarEagle1, 1 invisible),
172
6
Mod | | | Forums66 Topics128,284 Posts1,058,522 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2022 Posts: 10 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 10 | My son an I just replace my 66 C20's tank. I actually put the thank alone, then my son tied evrything together. It can be done without to much trouble. Watch out for the gas gauge wire. Put the neck on loose and place the tank. Adjust the neck so it doesn't stick out to far. Pull the tank again and tighten the neck, the put the tank in and tie it down. Good luck and stay safe. | | |
