One word of caution- - - -those flex lines run close to the exhaust pipe, and they can get brittle from heat. If a line springs a leak, it can dump all the oil in a pretty short time. I like to install a 6" long 1/8" NPT pipe nipple in the block at both attaching points to move the flex line away from the hot spot a little.
