| | | Forums66 Topics128,110 Posts1,056,245 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | if your brake drum is 14 inches across on the inside order the 1 ton brakes however to me it looks like someone just put in longer studs into a stock 3/4 ton axle
the brake cylinder in the photo looks like it is part 5450071 which is unique to the 3/4 ton in from 1946 to 1952 the 1 ton brake cylinder has larger solid cast gears on each end and those pads don't look like they would span 14 inches face to face to fit the 1 ton drum
the 3/4 ton rear brake shoe is the same part as the 1 ton front shoe the filling station shows they have them in stock, part number 3681116
-s | | |
