Originally Posted by Gdads51
Matt,
Would you share the part info/ID's on what you used???
Thanks! thumbs_up
I had the rod ends laying around from another project, but these are they: https://www.summitracing.com/parts/fkb-jmx10t
They use 5/8-18 threads and have a 5/8" diameter hole in the ball. They come in both left and right-hand threads, so you'll need one of each to make your drag link adjustable. Be sure to check the description so you get the correct threads.
I used a 10-inch swedge tube: https://www.summitracing.com/parts/aaf-all57164
The swedge tube has 5/8-18 threads at both ends, one left-hand and one right-hand, so the ends thread right in and it's adjustable by simply turning the tube.
I also used jam nuts in both left- and right-hand threads. These secure the swedge tube so it can't turn once you've set it:
https://www.summitracing.com/parts/qa1-jnr10s
https://www.summitracing.com/parts/qa1-jnl10s
And, of course, safety washers so if the rod end fails, it doesn't pop off: https://www.summitracing.com/parts/mez-sw58a
You can source the 5/8" nuts and bolts locally. I used grade-8 nylock nuts but you can also use castle nuts if you drill a cotter pin hole through the bolt. I used 2.5-inch grade-8 bolts, but I think I'm going to take it apart and use 3-inch bolts with another safety washer on the other side of the rod end. It's not going to come apart, but that's the right way to do it.
Hope this helps!
-- Matt Harwood
Cleveland, OH
1950 3600 Tow Truck
Little bit of a FrankenTruck
In the DITY Gallery
Harwood Motors
