| | | Forums66 Topics128,032 Posts1,055,519 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I they are off of the truck you can try air pressure in the brake line hole. If still stuck block the brake line hole and apply a grease gun to the brake bleader this method has never failed me. If the gun nozel won't fit the bleader remove the bleader and use a needle attachment in the bleader hole this will need firm pressure. If you try to drive the pistons you will ruin the spring and probly the pistons. | | |
