7 members (1955 1 Series, Lightholder's Dad, 55shaker, DuckRancher, Jon G, TexasA&M48Truck, 1 invisible),
70
3
Mod | | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | Is the distributor set up so that the #1 plug wire corresponds with the location of the rotor? Meaning...is the rotor pointing at the point on the distributor cap where the #1 plug wire is plugged in? And is the timing sequence correct? Condenser ok? Coil ok?
