Originally Posted by fixite7
KThomas I have battled a lot of oil leaks,would begin by being certain it is the seal,want to see where the drip is coming from. Might try some snake oil seal softener if engine has set a lot. Snake oil is usually brake fluid !!
I didn't think about the brake fluid trick!
Kevin
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
