| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2022 Posts: 100 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 100 | I’m in the process of gathering parts to do a 5spd transmission conversion on my 1946 1/2 ton short wheel base Chevrolet. What drive shaft do I need?
Is there a std size drive shaft that will work, or do I have to get a custom drive shaft made?
Doing an early 60’s Chevy truck differential. 92 or earlier S-10 5spd trans. Aftermarket 5spd adapter. Short style throw out bearing.
Which drive shaft?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
