I ditched mine altogether. Ran a steel tube from the oil distributor to a rubber section that passes through the valve cover to the rocker oiler. Plugged the holes through the water jacket with pipe plugs.
I drilled a hole through the valve cover and used a grommet where the hose goes through. Used a rubber line rated for oil/gas.
Did this eight years ago and no problems to date.
