| | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,778 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,778 | I'm looking to go the other direction- - - -lower gearing. Is there a lower ratio gearset than the 5.13:1 available for the 1 ton rear axle? I'm trying to decide what rear end to use on a doodlebug tractor I've got on the drawing board, and so far, I've got a choice between a 5.13 single speed axle and a vacuum shift 2 speed that can get down into the 8-something gear ratio on the low side. Power is going to be a Mercruiser 4 cylinder, with a turbo 350 automatic and a crash box 4 speed in tandem ahead of the drive axle. Jerry
