| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | We need more information...please.
For goodness sake if you have or had an original running engine and Hydramatic transmission, don't make changes now. It's like putting the cart before the horse. The absolute best carburetor is the one that came with the engine-transmission combination. I skimmed your past postings and didn't see anything about what you have other that a 1954 GMC plus your handle includes Hydramatic. I hope you took pictures and made notes of the shifter and throttle linkages before you pulled the engine. It will be agonizing to get it right again. Very few here can help guide you to get "Humpty-Dumpty" back together again and working correctly. If you plan to use another type transmission then please forgive my panic-ranting.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
