0 members (),
94
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | If by test the harness you mean checking continuity of each circuit, you can do that with a multimeter or powered test light. You'd have to identify each end of the circuit and put your probes on them to see if the meter beeps (or shows below 5 ohms) or the test light lights up. I'm not sure why you'd suspect a new harness to be bad, though.
