0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Fix the choke cable- - -it's necessary to choke the engine on a cold start. Unless you're getting the coolant warmed up to normal running temp after every cold start, the spark plugs will get sooty- - - -especially if you keep pouring gas down the carburetor throat. You're also one backfire away from a really bad fire if you keep pouring gas into the intake- - - -do you have a good extinguisher handy? Jerry
