| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | I've used the output air from a shop vac and a water manometer to do comparisons between ports at various valve lift settings. All it takes is an adapter between the vac hose and the port which can be positioned accurately and a flow control valve to bypass some of the airflow to prevent overloading the water column. The setup I built cost less that 50 bucks in supplies, and took about four hours to build. Jerry
