| | | Forums66 Topics128,285 Posts1,058,278 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 2,213 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,213 | Not sure if this could cause your symptoms... Check the pedal and linkage to make sure the piston is returning all the way when your foot is off the pedal. If there is a booster, you need to check the rod between the master and the booster.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
