| | | Forums66 Topics128,153 Posts1,056,827 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | Just opened up the rear in my 46 1/2 ton. Looks like it hasn’t had gear oil in it since the last inspection sticker. 1973. Still have more tear down to do BUT…if it’s not salvageable is there a late model open driveline with 6 LUGS that is easily usable. Will wind up with a T5 trans more than likely if I have to go this route. I have new lowering springs and blocks set up for the 1/2 ton rear end and would like to use them as well. Significant investment. Staying 6lug as I just did the 6 lug front disc conversion.
Appreciate your input
Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
