Hy Woogeroo, You can buy friction material with different co-efficients of friction depending on your application, then you can attach those linnings to your shoes using rivets or special bolts. Or you can buy your shoes and linnings pre assembled, or your local brake shop can attach linnings to your shoes for you, many ways to go, hope that helps.
