0 members (),
132
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,276 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | I agree with Jerry. The design is brilliant. My challenge was that my later model 250 has HEI ignition. There isn't anywhere for that wire to attach. I have it taped off under the hood. My other issue was no matter how long I stared at the carb and thought about it, I couldn't find a way to attach the bracket and switch to the carb. I ended up mounting the switch in a hole in the dash left when I removed the factory radio. To go back to direct drive I let off the gas while I punch the switch by hand, wait a second and get back on the gas. Drops out of OD no problem. It's kind of "country" but it works great. I use the OD constantly when driving around town. 2nd gear in OD is perfect for cruising around. As long as I'm not on a hill I can slip the clutch a little and take off in 2nd. Get up to speed (+/- 25mph) let off the gas, push in the clutch, let it out and I'm in OD. I drive it like a 2 speed trans. Using the clutch for OD isn't necessary but I feel like it cuts down on ware and tare.
Thanks
Larry
Entire Thread
overdrive, educate me
| Mike Burns | 08/09/2022 12:43 PM |
Re: overdrive, educate me
| DaveV | 08/09/2022 2:44 PM |
| buoymaker | 08/09/2022 3:03 PM |
| buoymaker | 08/09/2022 3:15 PM |
| Larry_58_Burb | 08/09/2022 4:23 PM |
| rfs56trk | 08/09/2022 8:16 PM |
| Jon G | 08/09/2022 8:56 PM |
| Wally / Montana | 08/09/2022 11:53 PM |
| crenwelge | 08/10/2022 4:21 AM |
| Larry_58_Burb | 08/10/2022 4:29 PM |
| fixite7 | 09/09/2022 12:40 AM |
| Hotrod Lincoln | 08/10/2022 4:47 PM |
| crenwelge | 08/11/2022 4:11 AM |
| klhansen | 08/11/2022 5:18 AM |
| Bill Hanlon | 08/11/2022 1:49 PM |
| 2ManyTrucks | 08/11/2022 2:04 PM |
| Bill Hanlon | 08/11/2022 2:09 PM |
| fixite7 | 09/09/2022 1:16 AM |
| rfs56trk | 08/11/2022 2:59 PM |
| Hotrod Lincoln | 08/11/2022 3:23 PM |
| Larry_58_Burb | 08/11/2022 4:29 PM |
| Hotrod Lincoln | 08/11/2022 4:58 PM |
| crenwelge | 08/12/2022 6:12 PM |
| High Plains | 08/30/2022 1:53 PM |
| buoymaker | 08/30/2022 2:17 PM |
| TewacaRanch | 08/31/2022 12:42 AM |
| Hotrod Lincoln | 08/31/2022 1:01 AM |
| TewacaRanch | 08/31/2022 3:00 AM |
| Hotrod Lincoln | 08/31/2022 3:19 AM |
| TewacaRanch | 09/01/2022 3:25 AM |
| Hotrod Lincoln | 09/01/2022 5:23 AM |
| Bill Hanlon | 09/01/2022 1:01 PM |
| Hotrod Lincoln | 09/01/2022 11:15 PM |
| EdPruss | 09/09/2022 2:50 AM | |
