0 members (),
132
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,276 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | You want to momentarily kill power to the engine so that the input torque to the transmission drops to nearly zero allowing the overdrive planetary lock pin to set properly without grinding and slipping over its home position As soon as the overdrive is fully engaged power is returned to the engine If all works well you barely notice the momentary subsecond engine cutout. -s | | | |
Entire Thread
overdrive, educate me
| Mike Burns | 08/09/2022 12:43 PM |
Re: overdrive, educate me
| DaveV | 08/09/2022 2:44 PM |
| buoymaker | 08/09/2022 3:03 PM |
| buoymaker | 08/09/2022 3:15 PM |
| Larry_58_Burb | 08/09/2022 4:23 PM |
| rfs56trk | 08/09/2022 8:16 PM |
| Jon G | 08/09/2022 8:56 PM |
| Wally / Montana | 08/09/2022 11:53 PM |
| crenwelge | 08/10/2022 4:21 AM |
| Larry_58_Burb | 08/10/2022 4:29 PM |
| fixite7 | 09/09/2022 12:40 AM |
| Hotrod Lincoln | 08/10/2022 4:47 PM |
| crenwelge | 08/11/2022 4:11 AM |
| klhansen | 08/11/2022 5:18 AM |
| Bill Hanlon | 08/11/2022 1:49 PM |
| 2ManyTrucks | 08/11/2022 2:04 PM |
| Bill Hanlon | 08/11/2022 2:09 PM |
| fixite7 | 09/09/2022 1:16 AM |
| rfs56trk | 08/11/2022 2:59 PM |
| Hotrod Lincoln | 08/11/2022 3:23 PM |
| Larry_58_Burb | 08/11/2022 4:29 PM |
| Hotrod Lincoln | 08/11/2022 4:58 PM |
| crenwelge | 08/12/2022 6:12 PM |
| High Plains | 08/30/2022 1:53 PM |
| buoymaker | 08/30/2022 2:17 PM |
| TewacaRanch | 08/31/2022 12:42 AM |
| Hotrod Lincoln | 08/31/2022 1:01 AM |
| TewacaRanch | 08/31/2022 3:00 AM |
| Hotrod Lincoln | 08/31/2022 3:19 AM |
| TewacaRanch | 09/01/2022 3:25 AM |
| Hotrod Lincoln | 09/01/2022 5:23 AM |
| Bill Hanlon | 09/01/2022 1:01 PM |
| Hotrod Lincoln | 09/01/2022 11:15 PM |
| EdPruss | 09/09/2022 2:50 AM | |
