0 members (),
132
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,276 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,520 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,520 | Mike I don't see that one of your questions has been answered. You can not add overdrive to the AD transmission (nor any torque tube transmission). But you can add overdrive to a Saginaw 4 speed transmission with a bit of work and it makes for an interesting (however some think not all that practical) transmission. Given that the overdrive transmissions out there are over 50 years old now and all, the T5 (as others have mentioned) is a really good option. If you go with overdrive (or the T5), you will need to abandon the torque tube and stock differential. Good luck.
Entire Thread
overdrive, educate me
| Mike Burns | 08/09/2022 12:43 PM |
Re: overdrive, educate me
| DaveV | 08/09/2022 2:44 PM |
| buoymaker | 08/09/2022 3:03 PM |
| buoymaker | 08/09/2022 3:15 PM |
| Larry_58_Burb | 08/09/2022 4:23 PM |
| rfs56trk | 08/09/2022 8:16 PM |
| Jon G | 08/09/2022 8:56 PM |
| Wally / Montana | 08/09/2022 11:53 PM |
| crenwelge | 08/10/2022 4:21 AM |
| Larry_58_Burb | 08/10/2022 4:29 PM |
| fixite7 | 09/09/2022 12:40 AM |
| Hotrod Lincoln | 08/10/2022 4:47 PM |
| crenwelge | 08/11/2022 4:11 AM |
| klhansen | 08/11/2022 5:18 AM |
| Bill Hanlon | 08/11/2022 1:49 PM |
| 2ManyTrucks | 08/11/2022 2:04 PM |
| Bill Hanlon | 08/11/2022 2:09 PM |
| fixite7 | 09/09/2022 1:16 AM |
| rfs56trk | 08/11/2022 2:59 PM |
| Hotrod Lincoln | 08/11/2022 3:23 PM |
| Larry_58_Burb | 08/11/2022 4:29 PM |
| Hotrod Lincoln | 08/11/2022 4:58 PM |
| crenwelge | 08/12/2022 6:12 PM |
| High Plains | 08/30/2022 1:53 PM |
| buoymaker | 08/30/2022 2:17 PM |
| TewacaRanch | 08/31/2022 12:42 AM |
| Hotrod Lincoln | 08/31/2022 1:01 AM |
| TewacaRanch | 08/31/2022 3:00 AM |
| Hotrod Lincoln | 08/31/2022 3:19 AM |
| TewacaRanch | 09/01/2022 3:25 AM |
| Hotrod Lincoln | 09/01/2022 5:23 AM |
| Bill Hanlon | 09/01/2022 1:01 PM |
| Hotrod Lincoln | 09/01/2022 11:15 PM |
| EdPruss | 09/09/2022 2:50 AM | |
