Orange, if your wheel dont turn and you cant brake off the shoes, then you only got one option left. Take the whole assembly off including the backing plate. It wont be pretty, and you need to get someone to help you lift it and keep it straight as it slides off. Make sure you block up the truck real well, and be careful pulling off. Big trucks make bigger owie's.
