| | | Forums66 Topics128,190 Posts1,057,342 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Since your truck is a 47 second series there is room for a big block. As far as stance is concerned you can set the frame at the desired height and then figure out how to put suspension that will work on it. Probably bags or coil overs are the main options. Any way you go is going to take MAJOR fabrication skill and the tools to do so. Flaming River and IDIDIT offer "shorty" steering columns where the steering shaft can be offset to clear engine. With even a stock BB the entire chassis/brakes/steering need major attention. Good luck.
Evan
Entire Thread
Thoughts, Opinions & Suggestions - 1947 4400 Rat Rod Project
| CTrujillo | 06/29/2022 3:03 AM |
| CTrujillo | 06/29/2022 1:27 AM |
Re: Thoughts, Opinions & Suggestions - 1947 4400 Rat Rod Project
| 69Cuda | 06/29/2022 1:41 AM |
| CTrujillo | 06/29/2022 3:00 AM |
| Rich'sToys | 06/29/2022 3:40 AM |
| buoymaker | 06/29/2022 10:45 AM |
| WE b OLD | 06/29/2022 7:53 PM |
| fixite7 | 07/24/2022 12:37 PM |
| Fibonachu | 06/29/2022 3:29 AM |
| Justhorsenround | 06/29/2022 12:23 PM |
| EdPruss | 06/29/2022 2:11 PM |
| Pvmt-Pndr | 06/29/2022 4:01 PM |
| Hotrod Lincoln | 06/29/2022 4:16 PM |
| Hotrod Lincoln | 06/29/2022 10:16 PM |
| coilover | 07/02/2022 4:09 AM |
| John L. | 07/25/2022 2:26 PM |
| 32vsnake | 07/25/2022 3:02 PM | |
