8 members (cmayna, Wally / Montana, Shade Baby, Goach2, Donf, dt235sd, Otto Skorzeny, Joe H),
60
0
Mod | | | Forums66 Topics128,119 Posts1,056,311 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 78 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 78 | Thank all of you for your responses. I need to study them and start sorting out the problem. What I have done so far probably doesn't make sense. There were 2 wires in addition to the power wire that could reach the outgoing switch terminal so made a split there. The other switch terminal had the power wire attached. Underneath the truck there were 2 wires that could join the brake wire to the taillights. Anyway, using the wiring diagram I need to sort out the miscellaneous wires. I use a short strck to keep the brake pedal depressed when checking lights. I made a split here. Both brake lights work when the pedal is depressed. The parking lights work f and r The left turning signals work f and r. When the right turning signals are activated both the left and right rear signals blink.. The right front blinks only while both rear turn signals blink. As I said i need ro go back and sort using the wiring diagram. | | |
