8 members (Deegs53, Gdads51, Wheelie, TUTS 59, stlcardinalsguy, Maybellene, Wally / Montana, Otto Skorzeny),
256
3
Mod | | | Forums66 Topics128,078 Posts1,056,022 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Originally the radio would have had a main power lead for the fuse and another wire that would power the dial light. That latter is meant to be connected to where the dash lights are connected on the headlight switch. This way the dial light is controlled by the dimmer. Sometimes if the switch has been replaced in the radio, there is no separate wire for the dial light, | | |
