| | | Forums66 Topics128,126 Posts1,056,351 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | Most oil based lubricants won't help a heat riser, due to the heat in that area. The residue left behind when the oil burns away can gum things up. You might try some Never-Seez, which is made from atomized aluminum powder and very high temperature grease, or powdered graphite in a squeeze tube that is usually used to lubricate lock cylinders. Jerry
