| | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | That looks like the clips that hold the pivot pins on a Huck brake system. Push on the fat side of the clip so that the skinny side moves out away from the pin. Use a flat head screwdriver to bend up the skinny part of the ring (the clip). With the skinny part bent up, you can easily push the clip off the pin.
Hope that makes sense! | | |
